Milwaukee 5262-21 Power Cord Replacement
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: step 1, image 1 of 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: step 2, image 1 of 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: step 3, image 1 of 2 Milwaukee 5262-21 Power Cord Replacement, Power Cord: step 3, image 2 of 2
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: step 4, image 1 of 3 Milwaukee 5262-21 Power Cord Replacement: step 4, image 2 of 3 Milwaukee 5262-21 Power Cord Replacement: step 4, image 3 of 3
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: step 5, image 1 of 3 Milwaukee 5262-21 Power Cord Replacement: step 5, image 2 of 3 Milwaukee 5262-21 Power Cord Replacement: step 5, image 3 of 3
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
Adrien Andrade-Cain
181 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 314
