Milwaukee Hackzall 2625-20 Motor Replacement
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: step 1, image 1 of 2 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: step 2, image 1 of 1
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: step 3, image 1 of 2 Milwaukee Hackzall 2625-20 Motor Replacement: step 3, image 2 of 2
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
2 Comments
Is there any chance to change only brushes in this motor?
Marcin Kędzior - Reply
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 40
All Time: 2,419
