Milwaukee Hackzall 2625-20 Terminal Block Replacement
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: step 1, image 1 of 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: step 2, image 1 of 1
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: step 3, image 1 of 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement: step 3, image 2 of 2
    • Use a soldering iron to melt any existing soldered attachments.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,484
