Milwaukee Hackzall 2625-20 Trigger Replacement
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: step 1, image 1 of 2 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: step 1, image 2 of 2
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: step 2, image 1 of 1
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: step 3, image 1 of 2 Milwaukee Hackzall 2625-20 Trigger Replacement: step 3, image 2 of 2
    • Remove the rest of the trigger assembly from the case.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,749
