Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: step 1, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: step 1, image 2 of 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 2 of 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: step 3, image 1 of 1
    • Gently move the trigger assembly out of the way and remove the switch from the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 26
All Time: 1,751
