Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement
Troy Conrad
Troy Conrad and 3 other contributors
Last updated on December 18, 2019
20 minutes
Difficult
Introduction
Go to step 1
This guide will demonstrate how to replace the Trigger Assembly on the Milwaukee Hex Impact Driver 2656-20. The First Two steps will cover disassembly of the drill. The only tool required for this repair is a T-10 Torx Screwdriver. The repair is considered Difficult in difficulty and will take approximately 20 minuets.
Parts
Tools
Show more…
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: step 1, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: step 1, image 2 of 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 2 of 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: step 3, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: step 3, image 2 of 2
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 4, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 4, image 2 of 2
    • Gently pull up on the trigger assembly to remove it from the case.
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 5, image 1 of 1
    • Remove the trigger assembly from the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 1,264
