Milwaukee Hole Hawg 1675-1 Field Replacement
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: step 1, image 1 of 1
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: step 2, image 1 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 2, image 2 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 2, image 3 of 3
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: step 3, image 1 of 2 Milwaukee Hole Hawg 1675-1 Field Replacement: step 3, image 2 of 2
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: step 4, image 1 of 2 Milwaukee Hole Hawg 1675-1 Field Replacement, Field: step 4, image 2 of 2
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: step 5, image 1 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 5, image 2 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 5, image 3 of 3
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: step 6, image 1 of 2 Milwaukee Hole Hawg 1675-1 Field Replacement: step 6, image 2 of 2
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: step 7, image 1 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 7, image 2 of 3 Milwaukee Hole Hawg 1675-1 Field Replacement: step 7, image 3 of 3
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: step 8, image 1 of 2 Milwaukee Hole Hawg 1675-1 Field Replacement: step 8, image 2 of 2
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: step 9, image 1 of 1
    • Lift the field out of the device, feeding the yellow wire through the handle.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 618
