Milwaukee Hole Hawg 1675-1 Switch Replacement
  1. Milwaukee Hole Hawg 1675-1 Switch Replacement, Switch: step 1, image 1 of 1
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Switch Replacement: step 2, image 1 of 2 Milwaukee Hole Hawg 1675-1 Switch Replacement: step 2, image 2 of 2
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screw.
  3. Milwaukee Hole Hawg 1675-1 Switch Replacement: step 3, image 1 of 3 Milwaukee Hole Hawg 1675-1 Switch Replacement: step 3, image 2 of 3 Milwaukee Hole Hawg 1675-1 Switch Replacement: step 3, image 3 of 3
    • Remove the top portion of the handle.
    • Pay special attention to where each wire connects.
    • Lift up on the switch and disconnect the wires.
    • Use a #0 flathead screwdriver to release tension on the wires.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,177
