Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement
  1. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Outer Casing: step 1, image 1 of 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: step 2, image 1 of 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: step 3, image 1 of 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: step 3, image 2 of 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: step 3, image 3 of 3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
  4. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: step 4, image 1 of 1
    • While holding the shell in one hand, pull the end of the broken forward/reverse shuttle out of the casing.
    • Set the broken forward/reverse shuttle aside.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,933
