Milwaukee M12 2407-20 Outer Casing Replacement
  1. Milwaukee M12 2407-20 Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Outer Casing Replacement: step 2, image 1 of 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 3,278
