Milwaukee M12 2407-20 Speed Selector Lever Replacement
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: step 1, image 1 of 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: step 2, image 1 of 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: step 3, image 1 of 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: step 3, image 2 of 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: step 3, image 3 of 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: step 4, image 1 of 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,608
