Milwaukee M18 2606-20 Circuit Board Replacement
  1. Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: step 1, image 1 of 2 Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: step 1, image 2 of 2
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
    • Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
  2. Milwaukee M18 2606-20 Circuit Board Replacement: step 2, image 1 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 2, image 2 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 2, image 3 of 3
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Circuit Board Replacement: step 3, image 1 of 2 Milwaukee M18 2606-20 Circuit Board Replacement: step 3, image 2 of 2
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Circuit Board Replacement: step 4, image 1 of 2 Milwaukee M18 2606-20 Circuit Board Replacement: step 4, image 2 of 2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Circuit Board Replacement: step 5, image 1 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 5, image 2 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the 4-pin and 5-pin connector, using the tweezers, from the circuit board.
  6. Milwaukee M18 2606-20 Circuit Board Replacement: step 6, image 1 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 6, image 2 of 3 Milwaukee M18 2606-20 Circuit Board Replacement: step 6, image 3 of 3
    • Desolder all of the wires connected to the circuit board.
    • When you take the circuitboard out of the case, watch for a spring that is in the back of the battery contacts as it can fly out.
One Comment
Replacement M18 Battery for Milwaukee Power Tool 2606-20
Type: Li-ion
Volt: 18V
Capacity: 5000mAh
Color: Black
Weight: 932g
Dimension: 141.15 x 78.00 x 73.95mm
Milwaukee 2606-20 Power Tool Batteries are made from the highest quality parts and are compatible with the Milwaukee cordless tools. And, this Milwaukee 2606-20 battery can be charged with original battery charger. Go to view more about this battery on https://www.drill-batteries.com/batteryp...
Drillbatterycomau - Reply
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 153
All Time: 9,083
