Milwaukee M18 2606-20 Gearbox Replacement
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: step 1, image 1 of 3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: step 1, image 2 of 3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: step 1, image 3 of 3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Gearbox Replacement: step 2, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement: step 2, image 2 of 2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: step 3, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement: step 3, image 2 of 2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: step 4, image 1 of 3 Milwaukee M18 2606-20 Gearbox Replacement: step 4, image 2 of 3 Milwaukee M18 2606-20 Gearbox Replacement: step 4, image 3 of 3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: step 5, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: step 5, image 2 of 2
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: step 6, image 1 of 3 Milwaukee M18 2606-20 Gearbox Replacement: step 6, image 2 of 3 Milwaukee M18 2606-20 Gearbox Replacement: step 6, image 3 of 3
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: step 7, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement: step 7, image 2 of 2
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: step 8, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement: step 8, image 2 of 2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: step 9, image 1 of 2 Milwaukee M18 2606-20 Gearbox Replacement: step 9, image 2 of 2
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 3,870
