Milwaukee M18 2606-20 Motor Replacement
  1. Milwaukee M18 2606-20 Motor Replacement, Motor: step 1, image 1 of 2 Milwaukee M18 2606-20 Motor Replacement, Motor: step 1, image 2 of 2
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
  2. Milwaukee M18 2606-20 Motor Replacement: step 2, image 1 of 3 Milwaukee M18 2606-20 Motor Replacement: step 2, image 2 of 3 Milwaukee M18 2606-20 Motor Replacement: step 2, image 3 of 3
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Motor Replacement: step 3, image 1 of 2 Milwaukee M18 2606-20 Motor Replacement: step 3, image 2 of 2
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Motor Replacement: step 4, image 1 of 2 Milwaukee M18 2606-20 Motor Replacement: step 4, image 2 of 2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Motor Replacement: step 5, image 1 of 2 Milwaukee M18 2606-20 Motor Replacement: step 5, image 2 of 2
    • Lift the motor from the casing.
  6. Milwaukee M18 2606-20 Motor Replacement: step 6, image 1 of 3 Milwaukee M18 2606-20 Motor Replacement: step 6, image 2 of 3 Milwaukee M18 2606-20 Motor Replacement: step 6, image 3 of 3
    • Remove the motor from the case and unscrew the two 8mm screws, using the T3 Torx Screwdriver, on the back of the motor.
    • Remove the connected wires.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 42
All Time: 3,778
