Introduction
You can use this guide to replace a damaged or missing shoe retainer on a Milwaukee Reciprocating Saw 6538-21-B36B (2010).
If you are noticing your Milwaukee Reciprocating Saw is making unprecise cuts or is becoming harder to control or stabilize, then you could have a problem with the shoe retainer.
The shoe retainer is an essential mechanism for supporting and guiding the saw blades during operation. The retainer ensures the blade stays in the position you guide the saw to, allowing for a precise and controlled cut. Having a working shoe retainer will decrease the chances of wear and tear from continued unstable use, while also decreasing the risks of kickback.
As always, remember to unplug the saw before any replacements.
Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
Use a Torx T20 screwdriver to remove the two 4.2 mm screws that secure the shoe retainer.
