Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement
  1. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Side Handle Case: step 1, image 1 of 1
    • Remove the battery by sliding it from the base.
  2. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 2, image 1 of 1
    • Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
  3. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 3, image 1 of 3 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 3, image 2 of 3 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 3, image 3 of 3
    • Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
  4. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 4, image 1 of 2 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 4, image 2 of 2
    • Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
  5. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 5, image 1 of 1
    • Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
  6. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 6, image 1 of 2 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 6, image 2 of 2
    • Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
  7. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement: step 7, image 1 of 1
    • Gently pry apart the covers for the drill handle.
  8. Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: step 8, image 1 of 2 Milwaukee Rotary Hammer 260520 D14A 2016 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: step 8, image 2 of 2
    • Locate the forward/reverse shuttle on the drill, just behind the drill trigger mechanism.
    • Gently pull the trigger down and remove the damaged fwd/rev shuttle.
    • Add in the replacement part, ensuring that the shuttle locks into place.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 65
