This teardown is not a repair guide. To repair your Mini muscle massage gun, use our service manual.
  1. Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 1 of 3 Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 2 of 3 Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 3 of 3
    • Device Overview
    • Dimension.
    • Red :98.30mm
    • Orange:116mm
    • Yellow:132.82mm
    • Diameter dimension
    • Red: 48.62mm Diameter
    • Hello 98.8mm Diameter
  2. Mini Muscle Massage Gun, Screws: step 2, image 1 of 3 Mini Muscle Massage Gun, Screws: step 2, image 2 of 3 Mini Muscle Massage Gun, Screws: step 2, image 3 of 3
    • To remove and disassemble the shell. Follow these instructions.
    • Unscrew all the screw hi lighted in the images.
    • unscrew the cap located at the tip of the device.
  3. Mini Muscle Massage Gun: step 3, image 1 of 3 Mini Muscle Massage Gun: step 3, image 2 of 3 Mini Muscle Massage Gun: step 3, image 3 of 3
    • Twist and remove the cap located on the back. hi lighted in red.
    • Carefully removed the connector from the PCB
    • Twist and removed the bottom cap. Hi lighted in yellow
  4. Mini Muscle Massage Gun, Dimension internal components.: step 4, image 1 of 2 Mini Muscle Massage Gun, Dimension internal components.: step 4, image 2 of 2
    • Battery length.
    • Orange. 66.64mm
    • Yellow: 71.28mm.
    • Battery Diameter.
    • Blue 42mm
    • Massage conector
    • Red:103.13mm
  5. Mini Muscle Massage Gun: step 5, image 1 of 3 Mini Muscle Massage Gun: step 5, image 2 of 3 Mini Muscle Massage Gun: step 5, image 3 of 3
    • Remove the top shell from the body.
    • Using a screw driver removed part hi lighted in red from the motor
    • Remove screw hi lighted in yellow. Removing this screw will disconnect the motor to the body.
  6. Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 1 of 3 Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 2 of 3 Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 3 of 3
    • Device handle shell is weighted at 50g . Made from ABS plastic. Injection mold
    • Top shell is weighted at 19g. Made from ABS plastic
    • The tip which is used to hold the shell parts together is weighted at 19g. Made from ABS plastic
  7. Mini Muscle Massage Gun, Teardown components cap: step 7, image 1 of 3 Mini Muscle Massage Gun, Teardown components cap: step 7, image 2 of 3 Mini Muscle Massage Gun, Teardown components cap: step 7, image 3 of 3
    • Back cap. This include the PCB. is weighted at 14g. Made from ABS plastic.
    • Bottom cap is weighted at 7g. Made from ABS plastic
    • Decoration parts. Non functional weighted at 3g.
  8. Mini Muscle Massage Gun, Internal components.: step 8, image 1 of 3 Mini Muscle Massage Gun, Internal components.: step 8, image 2 of 3 Mini Muscle Massage Gun, Internal components.: step 8, image 3 of 3
    • Battery. Weighted at 72g. use to power the devic. 1800mAh lithium battery
    • Part connected to the device motor. Use as a connect to various massager head. Weighted at 19g.
    • Device motor. Weighted at 246g.
  9. Mini Muscle Massage Gun, Massage gun interchanagble head: step 9, image 1 of 1
    • Red: Nylon: injection moulded
    • Blue: Rubber: injection moulded
    • Yellow: Eva foam:
  10. Mini Muscle Massage Gun, Teardown complete overview: step 10, image 1 of 1
    • Device design is quite simple which encourage repairability.
    • most part found in the device and be easily replace by purchasing them online
    • 1800mAh high-quality rechargeable lithium battery can be easily replaced online.
    • 30W high-torque motor can also be replace. Purchased online. https://www.hisgifts.com.au/products/sta...
    • Any broken parts of the shell can easily be fixed with 3d printing.
    • most screw can also be found online
Nathasorn Pantratthanamongkol
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 61
All Time: 899
