Minolta Dimage Xt Casing Replacement
  1. Minolta Dimage Xt Casing Replacement, Casing: step 1, image 1 of 3 Minolta Dimage Xt Casing Replacement, Casing: step 1, image 2 of 3 Minolta Dimage Xt Casing Replacement, Casing: step 1, image 3 of 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Casing Replacement: step 2, image 1 of 3 Minolta Dimage Xt Casing Replacement: step 2, image 2 of 3 Minolta Dimage Xt Casing Replacement: step 2, image 3 of 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
28 Reputation
5 Guides authored
Clemson, Team 12-4, Benson Spring 2013 Member of Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Members
14 Guides authored
One Comment
How to reattach the ribbon????
rosybrier - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 447
