Mio ALPHA 2 Battery Replacement
  1. Mio ALPHA 2 Battery Replacement, Battery: step 1, image 1 of 2 Mio ALPHA 2 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the 4 JIS 00 6.71 mm screws.
  2. Mio ALPHA 2 Battery Replacement: step 2, image 1 of 1
    • Pull off the back cover of the watch after the 4 screws are removed from the first step.
    • Be careful not to remove the Data Strip (Brown Strip) from either chip.
  3. Mio ALPHA 2 Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use some tweezers to remove the small white clip for the battery from the circuit board.
  4. Mio ALPHA 2 Battery Replacement: step 4, image 1 of 1
    • Slowly peel the battery off from the back cover of the watch.
    • There is double sided tape on the back side. Make sure to not tear up the tape. If the double sided tape is not reusable, replace with new tape.
Finish Line
3 other people completed this guide.
David Soder
155 Reputation
1 Guide authored
IUPUI, Team S22-G3, Bayer Fall 2017 Member of IUPUI, Team S22-G3, Bayer Fall 2017
IUPUI-BAYER-F17S22G3
4 Members
2 Guides authored
4 Guide Comments
What battery should I buy? Can you provide any specs about the battery itself?
Tabitha Romero - Reply
The Mio support team tells: “Unfortunatley, ALPHA 2 doesn't have replacable batteries “.
Any idea where we can buy such battery ?
vanlaetb - Reply
hi i managed to purchase the battery and replace it via Ali Express website. Search for battery size 302530 3.7v 300 mah Lithium . Thickness 3mm, width 25mm, length 30mm.
Take note when you replace the battery the wire that comes with the new battery wire will be too thick to insert into the mini small white clip. What i did was to cut off the old wire from the old battery and connect it with the new battery wire.
lhy011 -
Hi, Can you share me the link to buy the battery?
Thank you!!!
amoreno - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 24
All Time: 3,548
