MistAire Humidifier Cap Spring Replacement
  1. MistAire Humidifier Cap Spring Replacement, Cap Spring: step 1, image 1 of 2 MistAire Humidifier Cap Spring Replacement, Cap Spring: step 1, image 2 of 2
    • Lift the blue tank off of the base of the humidifier.
    • The two parts are not attached or snapped together, so they should separate easily.
  2. MistAire Humidifier Cap Spring Replacement: step 2, image 1 of 3 MistAire Humidifier Cap Spring Replacement: step 2, image 2 of 3 MistAire Humidifier Cap Spring Replacement: step 2, image 3 of 3
    • Turn the tank upside down.
    • Turn the round cap counterclockwise to completely unscrew it.
  3. MistAire Humidifier Cap Spring Replacement: step 3, image 1 of 2 MistAire Humidifier Cap Spring Replacement: step 3, image 2 of 2
    • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
    • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
  4. MistAire Humidifier Cap Spring Replacement: step 4, image 1 of 3 MistAire Humidifier Cap Spring Replacement: step 4, image 2 of 3 MistAire Humidifier Cap Spring Replacement: step 4, image 3 of 3
    • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
  5. MistAire Humidifier Cap Spring Replacement: step 5, image 1 of 2 MistAire Humidifier Cap Spring Replacement: step 5, image 2 of 2
    • Once the ring is off, pull the rod and spring out from the center of the cap.
  6. MistAire Humidifier Cap Spring Replacement: step 6, image 1 of 2 MistAire Humidifier Cap Spring Replacement: step 6, image 2 of 2
    • Slide the broken spring off of the rod.
    • The spring should come off easily.
  7. MistAire Humidifier Cap Spring Replacement: step 7, image 1 of 2 MistAire Humidifier Cap Spring Replacement: step 7, image 2 of 2
    • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
    • Ensure the narrower end of the cone-shaped spring goes first.
  8. MistAire Humidifier Cap Spring Replacement: step 8, image 1 of 2 MistAire Humidifier Cap Spring Replacement: step 8, image 2 of 2
    • Pinch the spring gently to secure it around the rod.
    • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
  9. MistAire Humidifier Cap Spring Replacement: step 9, image 1 of 3 MistAire Humidifier Cap Spring Replacement: step 9, image 2 of 3 MistAire Humidifier Cap Spring Replacement: step 9, image 3 of 3
    • Push the small blue ring back onto the pointed end of the rod.
    • You should hear a snap when it’s secured.
  10. MistAire Humidifier Cap Spring Replacement: step 10, image 1 of 3 MistAire Humidifier Cap Spring Replacement: step 10, image 2 of 3 MistAire Humidifier Cap Spring Replacement: step 10, image 3 of 3
    • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
  11. MistAire Humidifier Cap Spring Replacement: step 11, image 1 of 3 MistAire Humidifier Cap Spring Replacement: step 11, image 2 of 3 MistAire Humidifier Cap Spring Replacement: step 11, image 3 of 3
    • Place the tank back onto the humidifier base.
    • You have now successfully replaced the spring in the MistAire Humidifier!
Finish Line
Abby
193 Reputation
1 Guide authored
UC Davis, Team 1-1, Andersen Winter 2024 Member of UC Davis, Team 1-1, Andersen Winter 2024
UCD-ANDERSEN-W24S1G1
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 42
Past 30 Days: 160
All Time: 883
