Mitsubishi 3000GT Engine Assembly (6G72 DOHC)
  1. Mitsubishi 3000GT Engine Assembly (6G72 DOHC), Assembly Tips: step 1, image 1 of 2 Mitsubishi 3000GT Engine Assembly (6G72 DOHC), Assembly Tips: step 1, image 2 of 2
    • Clean and inspect all parts, removing paint, rust, gunk, and grit. This is very important for internal components.
    • Reusing worn or damaged parts may result engine failure. Your local machine shop or engine builder can usually recondition worn parts rather than replace them.
    • Assemble the engine in a clean and dust free work area. Place oiled parts on a lint-free rag to avoid picking up debris from the work surface.
    • Use a tap to clean out threads before assembling parts.
  2. Mitsubishi 3000GT Engine Assembly (6G72 DOHC), Cylinder Block: step 2, image 1 of 2 Mitsubishi 3000GT Engine Assembly (6G72 DOHC), Cylinder Block: step 2, image 2 of 2
    • Use a cylinder hone and drill to prepare the cylinder walls. First clean the walls, then lubricate with diesel fuel or engine oil before honing.
    • Vary the drill speed and up/down motions to achieve a 30 degree cross hatch pattern on the walls.
    • This process removes any glazing and restores the correct surface finish needed for the piston rings to seal.
    • Make sure to clean the cylinder walls and remove all grit created by the honing process.
  3. Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 3, image 1 of 2 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 3, image 2 of 2
    • Install the following expansion plugs using a socket and hammer:
    • One 41.5mm plug (right side)
    • Two 35mm plugs (rear)
    • Five 25mm plugs (left and right sides)
  4. Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 4, image 1 of 3 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 4, image 2 of 3 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 4, image 3 of 3
    • Install the two threaded hex plugs (front and rear) using an 8mm hex wrench.
    • Install the two threaded coolant plugs (left and right side) using a 14mm wrench.
    • Apply sealant or pipe tape to the plug threads.
  5. Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 5, image 1 of 3 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 5, image 2 of 3 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 5, image 3 of 3
    • This step is for turbo engines only.
    • Install the six oil squirters into the angled holes in the main bearing journals using a punch and hammer.
    • Make sure each oil squirter is fully seated and below the bottom of the oil feed groove.
    • Do not install oil squirters in the center oil feed holes.
    • Install the main bearings into the block and girdle.
    • Install the grooved bearings in the block side.
    • Make sure the journal surfaces underneath are clean and dry.
    • Carefully install the crankshaft into the block.
    • Make sure the bearings are clean and dry.
    • Do not rotate the crankshaft after it is installed.
    • Add a small length of Plastigauge to each bearing journal.
    • Carefully set the girdle onto the crankshaft. Line it up perfectly with the bearing journals on the block.
    • The girdle fits very tightly into the block and will not be fully seated until the next step.
    • Apply engine oil to the main bolt threads and underside of the head.
    • Do not dip the bolt in engine oil. Too much oil may damage the block.
    • Install the main bolts. Evenly tighten until snug using a socket wrench and 17mm socket.
    • Tap the girdle with a soft-faced hammer while continuing to snug the main bolts until the girdle is fully seated.
  6. Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 9, image 1 of 2 Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 9, image 2 of 2
    • Install the main cap bolts and tighten them by hand.
    • Two-bolt blocks will have eight bolts total.
    • Four-bolt blocks will have 16 bolts total.
    • Use a torque wrench and a 17mm socket to tighten the main bolts to the specified torque:
    • Two-bolt blocks: 67 ft-lbs (93 Nm)
    • Four-bolt blocks: 54 ft-lbs (74 Nm)
    • Tighten bolts in the sequence shown.
    • Loosen the main bolts and carefully remove the girdle.
    • Measure the width of the Plastigauge to determine the bearing clearance of each journal.
    • Main bearing clearance should be 0.0008-0.0020 in (0.020-0.050 mm).
    • Do not continue if bearing clearances are out of spec. Double check that the main bearings, crankshaft, and girdle are installed correctly and that the crankshaft isn't excessively worn.
    • Remove the crankshaft.
    • Apply assembly lube to the smooth side of the thrust washers.
    • Stick the thrust washers onto the sides of the #3 journal on both the block and girdle.
    • The thrust washer grooves face away from the bearing journals.
    • Apply assembly lube or engine oil to the main bearings and thrust washers.
    • Reinstall the crankshaft and girdle.
    • Be careful not to knock the thrust washers out of position.
    • Reinstall the main bolts and repeat Step 8.
    • Spin the crankshaft one complete rotation. It should spin smoothly throughout.
    • Attach a dial indicator to the nose of the crankshaft to measure end play.
    • Use a large flathead screwdriver to carefully move the crankshaft side to side. Zero the indicator at one extreme, then take a measurement at the other extreme.
    • Crankshaft end play should be 0.0020-0.0098 in (0.050-0.250 mm).
    • Do not continue if the end play is out of spec. Double check that the thrust washers are installed correctly and of the correct thickness.
    • This step is for two-bolt turbo engines only.
    • Install the four girdle side stays.
    • One stay is shaped differently and goes in the front-right position.
    • Install the eight side stay bolts. Apply engine oil to the threads and underneath the bolt head.
    • Do not dip the entire bolt in engine oil. This may damage the block.
    • Use a 14mm wrench to snug all bolts.
    • Use a torque wrench and 14mm socket to tighten the girdle-side bolts, followed by the block-side bolts.
    • The torque is 35 ft-lbs (48 Nm).
    • Insert wisdom here.
    • Install the head gaskets on the cylinder block.
    • Install heads onto block, being careful the head gasket stays in position.
    • Install head bolts and hand tighten.
  7. Mitsubishi 3000GT Engine Assembly (6G72 DOHC): step 20, image 1 of 1
    • Use a torque wrench to tighten the head bolts in three even steps:
    • N/A Engines: 26, 52, 80 ft-lbs (36, 72, 110 Nm)
    • Turbo Engines: 30, 60, 90 ft-lbs (41, 82, 125 Nm)
    • Tighten all bolts to the specified torque before increasing to the next torque step.
Finish Line
2 other people completed this guide.
Ian Glen
651 Reputation
3 Guides authored
One Comment
GREAT info!! My first complete build and I'm NERVOUS!! Still trying to figure out where certain items go.
From my complete gasket kit I can't seem to find info on where the small copper crush washers go and the small O Rings. Would appreciate your info. THANKS!!
Jef Lawlor - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 46
All Time: 1,364
