Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
  1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: step 1, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: step 1, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: step 1, image 3 of 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: step 2, image 1 of 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: step 3, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: step 3, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: step 3, image 3 of 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: step 4, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: step 4, image 2 of 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: step 5, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: step 5, image 2 of 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: step 6, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: step 6, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: step 6, image 3 of 3
    • Remove all the cables.
  7. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: step 7, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: step 7, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: step 7, image 3 of 3
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement: step 8, image 1 of 1
    • Now you can replace it with a new one.
Padraic Hoselton
4,204 Reputation
12 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 163
