Mitsubishi Electric DD-6040 Power Button Replacement
  1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: step 1, image 1 of 3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: step 1, image 2 of 3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: step 1, image 3 of 3
    • Unplug your DVD player prior to working on the device.
    • Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
  2. Mitsubishi Electric DD-6040 Power Button Replacement: step 2, image 1 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 2, image 2 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 2, image 3 of 3
    • Once the screws are removed, slide back and remove the cover.
  3. Mitsubishi Electric DD-6040 Power Button Replacement: step 3, image 1 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 3, image 2 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 3, image 3 of 3
    • Gently pull out the green circuit board.
    • Be very careful, as circuit boards can be quite fragile.
  4. Mitsubishi Electric DD-6040 Power Button Replacement: step 4, image 1 of 2 Mitsubishi Electric DD-6040 Power Button Replacement: step 4, image 2 of 2
    • Flip the DVD player over and pull up on the clip.
  5. Mitsubishi Electric DD-6040 Power Button Replacement: step 5, image 1 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 5, image 2 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 5, image 3 of 3
    • Once the clip is unlatched disconnect the corner tabs.
    • Reorient and unlatch the tabs inside the device.
    • Remove the faceplate.
  6. Mitsubishi Electric DD-6040 Power Button Replacement: step 6, image 1 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 6, image 2 of 3 Mitsubishi Electric DD-6040 Power Button Replacement: step 6, image 3 of 3
    • Pull on the old power button to remove it.
  7. Mitsubishi Electric DD-6040 Power Button Replacement: step 7, image 1 of 2 Mitsubishi Electric DD-6040 Power Button Replacement: step 7, image 2 of 2
    • Adjust and push the new button into place.
To reassemble your device, follow these steps in reverse order.
Usha Alexis
199 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 346
