Mitsubishi MMCS NR-242 Firmware Update
  1. Mitsubishi MMCS NR-242 Firmware Update, Identify your Revision: step 1, image 1 of 1
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • In this case the Version Number is W-12.
  2. Mitsubishi MMCS NR-242 Firmware Update, Download the Firmware: step 2, image 1 of 2 Mitsubishi MMCS NR-242 Firmware Update, Download the Firmware: step 2, image 2 of 2
    • You can download the firmware files here: Version CR, CZ and CI.
    • Check if the Firmware Version works with your device.
    • MMCS E-11 and E-12 are analogues of W-13.
    • Download the Firmware for your device.
    • Press on SHOW ALL.
    • Download LOADING.KWI.
  3. Mitsubishi MMCS NR-242 Firmware Update, Move the File: step 3, image 1 of 1
    • The SD card needs to be formatted to FAT32. If it’s not already formatted to FAT32 and you don’t know how to do it, you can take a look at this guide.
    • Copy the LOADING.KWI file to the root directory of the SD Card.
  4. Mitsubishi MMCS NR-242 Firmware Update, Flip up the Display: step 4, image 1 of 2 Mitsubishi MMCS NR-242 Firmware Update, Flip up the Display: step 4, image 2 of 2
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  5. Mitsubishi MMCS NR-242 Firmware Update, Insert the SD Card: step 5, image 1 of 1
    • Insert the SD Card into the USER-Slot.
    • Close the display by pressing the OPEN-Button again.
  6. Mitsubishi MMCS NR-242 Firmware Update, Update the Firmware: step 6, image 1 of 1
    • The Unit will automatically detect the Firmware file and ask you if you want to update.
    • Press the Update-Button on the screen to proceed.
    • Do not turn off the car while the update is running!
  7. Mitsubishi MMCS NR-242 Firmware Update, Remove the SD Card: step 7, image 1 of 1
    • After the update is finished, remove the SD Card by repeating Step 4 and 5.
Drive safe!
3 other people completed this guide.
Sebastian
23,881 Reputation
65 Guides authored
German Translators Member of German Translators
Community
28 Members
809 Guides authored
0 Comments
Past 24 Hours: 33
Past 7 Days: 135
Past 30 Days: 643
All Time: 9,446
