Mizuno GFE1251 Baseball Glove Lacing Replacement
  1. Mizuno GFE1251 Baseball Glove Lacing Replacement, Lacing: step 1, image 1 of 1
    • Untie the knot 1.
    • If you are having trouble, you can cut it with scissors.
  2. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 2, image 1 of 1
    • From where the knot was, start unweaving the lacing.
    • To unweave the lacing, pull it through all of the holes, until you get to the next section.
    • The lacing is hard to pull through the glove and requires quite a bit of manpower.
    • The first section continues up until the pocket.
  3. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 3, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 3, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 3, image 3 of 3
    • This section is difficult to unlace and may need the assistance of a tool to get it lose. We have used the unlacing/lacing tool that came with the our kit.
    • This is the pocket section.
  4. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 4, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 4, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 4, image 3 of 3
    • Trace along the pocket and when you come to the end untie the knot.
    • We have now unlaced all of the glove.
  5. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 5, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 5, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 5, image 3 of 3
    • Start by weaving the lace through the lacing tool as shown.
    • Weave through spot A and then tie a knot.
    • Weave the lace through the pattern shown
  6. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 6, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 6, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 6, image 3 of 3
    • Weave the lace through spot B.
    • Follow the pattern shown and tie a knot at spot C.
    • Make sure to pull this section tighter than the rest.
    • Cut off the extra lace.
    • We have now used the first length of lace.
  7. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 7, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 7, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 7, image 3 of 3
    • Weave through spot D and then tie a knot.
    • Follow the pattern shown.
  8. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 8, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 8, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 8, image 3 of 3
    • Tie a knot at spot E and cut off the left over lace.
    • We will be using this lace in the next step.
  9. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 9, image 1 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 9, image 2 of 3 Mizuno GFE1251 Baseball Glove Lacing Replacement: step 9, image 3 of 3
    • Weave through spot F and tie a knot.
    • Weave through spot G and tie a knot.
    • Spot G has another piece of lace in it but it opens up in two different spots.
  10. Mizuno GFE1251 Baseball Glove Lacing Replacement: step 10, image 1 of 1
    • Congratulations, you now have relaced your old baseball glove!
Enjoy your newly-repaired baseball glove.
Chandler Torres
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 4,077
