Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement
  1. Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement, Blade Cover: step 1, image 1 of 3 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement, Blade Cover: step 1, image 2 of 3 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement, Blade Cover: step 1, image 3 of 3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 2, image 1 of 2 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 2, image 2 of 2
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 3, image 1 of 2 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 3, image 2 of 2
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 4, image 1 of 3 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 4, image 2 of 3 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 4, image 3 of 3
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 5, image 1 of 2 Mk Diamond Wet Saws MK660 2010 Blade Cover Replacement: step 5, image 2 of 2
    • Pivot the blade cover up and pull it off the shaft.
Carsten Frauenheim
117,932 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 109
