Modal MD-SPBT01 LED Light Wiring Replacement
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: step 1, image 1 of 2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: step 1, image 2 of 2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: step 2, image 1 of 1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: step 3, image 1 of 1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: step 4, image 1 of 1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: step 5, image 1 of 1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: step 6, image 1 of 1
    • Now with the LED wiring removed, a new wire can be installed.
Nathan Hall
258 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 749
