Modal MD-WORCSS6 Battery Replacement
  1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 1 of 2 Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 2 of 2
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 Battery Replacement: step 2, image 1 of 2 Modal MD-WORCSS6 Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 Battery Replacement: step 3, image 1 of 2 Modal MD-WORCSS6 Battery Replacement: step 3, image 2 of 2
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 Battery Replacement: step 4, image 1 of 3 Modal MD-WORCSS6 Battery Replacement: step 4, image 2 of 3 Modal MD-WORCSS6 Battery Replacement: step 4, image 3 of 3
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 Battery Replacement: step 5, image 1 of 3 Modal MD-WORCSS6 Battery Replacement: step 5, image 2 of 3 Modal MD-WORCSS6 Battery Replacement: step 5, image 3 of 3
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 Battery Replacement, Battery: step 6, image 1 of 1
    • Replace the batteries by pulling them out of their holder and putting new ones in the same places.
3 other people completed this guide.
1 Guide Comment
Where do you get the replacement batteries?
Gerry David - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,374
