Modal MD-WORCSS6 LED Replacement
  1. Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 1 of 2 Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 2 of 2
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 LED Replacement: step 2, image 1 of 2 Modal MD-WORCSS6 LED Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 LED Replacement: step 3, image 1 of 2 Modal MD-WORCSS6 LED Replacement: step 3, image 2 of 2
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 LED Replacement: step 4, image 1 of 3 Modal MD-WORCSS6 LED Replacement: step 4, image 2 of 3 Modal MD-WORCSS6 LED Replacement: step 4, image 3 of 3
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 LED Replacement: step 5, image 1 of 3 Modal MD-WORCSS6 LED Replacement: step 5, image 2 of 3 Modal MD-WORCSS6 LED Replacement: step 5, image 3 of 3
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 LED Replacement, LED: step 6, image 1 of 3 Modal MD-WORCSS6 LED Replacement, LED: step 6, image 2 of 3 Modal MD-WORCSS6 LED Replacement, LED: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Slide the circuit board out of its slot.
    • Remove the LEDs by clipping off their connections with a pair of tweezers.
    • Attach the new LEDs by soldering the ends of the LEDS to their corresponding connections on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 174
