Moen Posi-Temp Cartridge Part #1112b Replacement
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: step 1, image 1 of 1
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: step 2, image 1 of 1
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: step 3, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 3, image 2 of 2
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: step 4, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 4, image 2 of 2
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: step 5, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 5, image 2 of 2
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: step 6, image 1 of 1
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 3 of 3
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 3 of 3
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 3 of 3
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 3 of 3
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: step 11, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 11, image 2 of 2
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: step 12, image 1 of 1
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
John Mendoza
205 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,219
