Monster SoundStage S1 Mini Speaker Replacement
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: step 1, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: step 1, image 2 of 2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: step 2, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 2, image 2 of 2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: step 3, image 1 of 1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: step 4, image 1 of 3 Monster SoundStage S1 Mini Speaker Replacement: step 4, image 2 of 3 Monster SoundStage S1 Mini Speaker Replacement: step 4, image 3 of 3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: step 5, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 5, image 2 of 2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: step 6, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 6, image 2 of 2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Heather Carrillo
412 Reputation
2 Guides authored
CSU Fullerton, Team 2-6, Bruce Fall 2016 Member of CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 512
