Monster Soundstage S2 Front Panel Replacement
  1. Monster Soundstage S2 Front Panel Replacement, Speaker Grille: step 1, image 1 of 2 Monster Soundstage S2 Front Panel Replacement, Speaker Grille: step 1, image 2 of 2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Front Panel Replacement: step 2, image 1 of 3 Monster Soundstage S2 Front Panel Replacement: step 2, image 2 of 3 Monster Soundstage S2 Front Panel Replacement: step 2, image 3 of 3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Front Panel Replacement: step 3, image 1 of 1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Front Panel Replacement: step 4, image 1 of 3 Monster Soundstage S2 Front Panel Replacement: step 4, image 2 of 3 Monster Soundstage S2 Front Panel Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Front Panel Replacement: step 5, image 1 of 2 Monster Soundstage S2 Front Panel Replacement: step 5, image 2 of 2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Front Panel Replacement: step 6, image 1 of 2 Monster Soundstage S2 Front Panel Replacement: step 6, image 2 of 2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Front Panel Replacement: step 7, image 1 of 3 Monster Soundstage S2 Front Panel Replacement: step 7, image 2 of 3 Monster Soundstage S2 Front Panel Replacement: step 7, image 3 of 3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Front Panel Replacement: step 8, image 1 of 1
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Front Panel Replacement, Front Speakers: step 9, image 1 of 3 Monster Soundstage S2 Front Panel Replacement, Front Speakers: step 9, image 2 of 3 Monster Soundstage S2 Front Panel Replacement, Front Speakers: step 9, image 3 of 3
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Front Panel Replacement: step 10, image 1 of 2 Monster Soundstage S2 Front Panel Replacement: step 10, image 2 of 2
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Front Panel Replacement: step 11, image 1 of 3 Monster Soundstage S2 Front Panel Replacement: step 11, image 2 of 3 Monster Soundstage S2 Front Panel Replacement: step 11, image 3 of 3
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Front Panel Replacement, Front Panel: step 12, image 1 of 2 Monster Soundstage S2 Front Panel Replacement, Front Panel: step 12, image 2 of 2
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Front Panel Replacement: step 13, image 1 of 1
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Front Panel Replacement: step 14, image 1 of 2 Monster Soundstage S2 Front Panel Replacement: step 14, image 2 of 2
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Front Panel Replacement: step 15, image 1 of 2 Monster Soundstage S2 Front Panel Replacement: step 15, image 2 of 2
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
2 other people completed this guide.
Shaw Hughes
831 Reputation
5 Guides authored
Cal Poly, Team 21-5, Maness Winter 2017 Member of Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 548
