Monster Soundstage S2 Rear Panel Connectors Replacement
  1. Monster Soundstage S2 Rear Panel Connectors Replacement, Speaker Grille: step 1, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement, Speaker Grille: step 1, image 2 of 2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Rear Panel Connectors Replacement: step 2, image 1 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 2, image 2 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 2, image 3 of 3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Rear Panel Connectors Replacement: step 3, image 1 of 1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Rear Panel Connectors Replacement: step 4, image 1 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 4, image 2 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Rear Panel Connectors Replacement: step 5, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 5, image 2 of 2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Rear Panel Connectors Replacement: step 6, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 6, image 2 of 2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Rear Panel Connectors Replacement: step 7, image 1 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 7, image 2 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 7, image 3 of 3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Rear Panel Connectors Replacement: step 8, image 1 of 1
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: step 9, image 1 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: step 9, image 2 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: step 9, image 3 of 3
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Rear Panel Connectors Replacement: step 10, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 10, image 2 of 2
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Rear Panel Connectors Replacement: step 11, image 1 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 11, image 2 of 3 Monster Soundstage S2 Rear Panel Connectors Replacement: step 11, image 3 of 3
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Rear Panel Connectors Replacement, Front Panel: step 12, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Panel: step 12, image 2 of 2
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Rear Panel Connectors Replacement: step 13, image 1 of 1
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Rear Panel Connectors Replacement: step 14, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 14, image 2 of 2
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Rear Panel Connectors Replacement: step 15, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 15, image 2 of 2
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
  16. Monster Soundstage S2 Rear Panel Connectors Replacement, Rear Panel Connectors: step 16, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement, Rear Panel Connectors: step 16, image 2 of 2
    • Use a TR 10 driver to remove the two 10mm screws securing the connector housing.
    • Remove the housing from the rear panel.
    • Do not stress or tear the cables that connect this part to the logic board.
  17. Monster Soundstage S2 Rear Panel Connectors Replacement: step 17, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 17, image 2 of 2
    • With the housing free from the speaker, the two daughterboards can be seen in the housing.
    • Gently remove both boards from the housing.
    • Be aware of the fragile ribbon connector that runs between the boards, as well as the cords that run to the logic board.
  18. Monster Soundstage S2 Rear Panel Connectors Replacement: step 18, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 18, image 2 of 2
    • Unplug the ribbon cable that connects the daughterboards from the top board. Leave the cable connected to the bottom board.
    • In order to remove the ribbon cable, gently pull the brown retention mechanism away from the connector. The ribbon cable can then be freely removed.
  19. Monster Soundstage S2 Rear Panel Connectors Replacement: step 19, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 19, image 2 of 2
    • Gently unplug the red power connector from the top daughterboard.
    • Note the correct orientation of this connector for reassembly.
  20. Monster Soundstage S2 Rear Panel Connectors Replacement: step 20, image 1 of 2 Monster Soundstage S2 Rear Panel Connectors Replacement: step 20, image 2 of 2
    • Gently pull out the large ribbon cable from the bottom logic board. Grasp the cable as close to the connector as possible and pull it straight away from the board.
    • There is no retention mechanism on this connector.
2 other people completed this guide.
Shaw Hughes
831 Reputation
5 Guides authored
Cal Poly, Team 21-5, Maness Winter 2017 Member of Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 244
