Montgomery Ward GEN-39500 Antenna Replacement
  1. Montgomery Ward GEN-39500 Antenna Replacement, Back Cover: step 1, image 1 of 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Antenna Replacement: step 2, image 1 of 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Antenna Replacement: step 3, image 1 of 2 Montgomery Ward GEN-39500 Antenna Replacement: step 3, image 2 of 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Antenna Replacement, Antenna: step 4, image 1 of 2 Montgomery Ward GEN-39500 Antenna Replacement, Antenna: step 4, image 2 of 2
    • Unsolder the wire connecting the antenna to the radio.
  5. Montgomery Ward GEN-39500 Antenna Replacement: step 5, image 1 of 1
    • Tilt the back cover up and remove the two 7.5 mm Phillips screws holding the antenna in place.
  6. Montgomery Ward GEN-39500 Antenna Replacement: step 6, image 1 of 1
    • Remove the antenna.
Dustin Platt
931 Reputation
6 Guides authored
Cal Poly, Team 12-5, Lancaster Spring 2015 Member of Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 146
