Montgomery Ward GEN-39500 Back Cover Replacement
  1. Montgomery Ward GEN-39500 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Back Cover Replacement: step 2, image 1 of 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Back Cover Replacement: step 3, image 1 of 2 Montgomery Ward GEN-39500 Back Cover Replacement: step 3, image 2 of 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
Dustin Platt
931 Reputation
6 Guides authored
Cal Poly, Team 12-5, Lancaster Spring 2015 Member of Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 106
