Montgomery Ward GEN-39500 Subwoofer Replacement
  1. Montgomery Ward GEN-39500 Subwoofer Replacement, Back Cover: step 1, image 1 of 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Subwoofer Replacement: step 2, image 1 of 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Subwoofer Replacement: step 3, image 1 of 2 Montgomery Ward GEN-39500 Subwoofer Replacement: step 3, image 2 of 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: step 4, image 1 of 2 Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: step 4, image 2 of 2
    • Unsolder the wires leading to and from the subwoofer.
  5. Montgomery Ward GEN-39500 Subwoofer Replacement: step 5, image 1 of 1
    • Unscrew the four 12.5 mm Phillips screws holding the subwoofer in place.
    • One of the screws holds down a metal cable organizer. For better cable organization after reassembly keep track of this organizer.
  6. Montgomery Ward GEN-39500 Subwoofer Replacement: step 6, image 1 of 1
    • Remove the subwoofer.
    • The process is the same for both sides.
Dustin Platt
931 Reputation
6 Guides authored
Cal Poly, Team 12-5, Lancaster Spring 2015 Member of Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 136
