Montiss Air bubble Massage Machine Fuse Replacement
  1. Montiss Air bubble Massage Machine Fuse Replacement, Fuse: step 1, image 1 of 1
    • Place the product in front of you
  2. Montiss Air bubble Massage Machine Fuse Replacement: step 2, image 1 of 2 Montiss Air bubble Massage Machine Fuse Replacement: step 2, image 2 of 2
    • Grab the tube, twist it and take it out.
  3. Montiss Air bubble Massage Machine Fuse Replacement: step 3, image 1 of 1
    • Turn the product upside down, you will see five holes, in which the screws are located.
  4. Montiss Air bubble Massage Machine Fuse Replacement: step 4, image 1 of 3 Montiss Air bubble Massage Machine Fuse Replacement: step 4, image 2 of 3 Montiss Air bubble Massage Machine Fuse Replacement: step 4, image 3 of 3
    • Use a Phillips screwdriver to loosen the screws, then turn the product right side up to get the screws out of the casing.
  5. Montiss Air bubble Massage Machine Fuse Replacement: step 5, image 1 of 1
    • Place the product on its feet and place the upper part of the casing next to the bottom part.
  6. Montiss Air bubble Massage Machine Fuse Replacement: step 6, image 1 of 2 Montiss Air bubble Massage Machine Fuse Replacement: step 6, image 2 of 2
    • An electronic wire is connecting the two PCB’s. Take off the PCB in the lower part of the case by gently pulling the plastic housing, the connection will slowly loosen.
  7. Montiss Air bubble Massage Machine Fuse Replacement: step 7, image 1 of 2 Montiss Air bubble Massage Machine Fuse Replacement: step 7, image 2 of 2
    • Take the PCB out of the case. Here you can see the fuse you want to replace
  8. Montiss Air bubble Massage Machine Fuse Replacement: step 8, image 1 of 3 Montiss Air bubble Massage Machine Fuse Replacement: step 8, image 2 of 3 Montiss Air bubble Massage Machine Fuse Replacement: step 8, image 3 of 3
    • Desolder the two spots connecting the fuse to the PCB. If you have never done this before, use this guide from iFixIt.
  9. Montiss Air bubble Massage Machine Fuse Replacement: step 9, image 1 of 2 Montiss Air bubble Massage Machine Fuse Replacement: step 9, image 2 of 2
    • Take out the fuse with some pliers, since it will be hot because of the soldering.
  10. Montiss Air bubble Massage Machine Fuse Replacement: step 10, image 1 of 2 Montiss Air bubble Massage Machine Fuse Replacement: step 10, image 2 of 2
    • Put in a new fuse and solder it back in place. Now you can reassemble the product.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 546
