Moosoo XL-618A Battery Replacement
  1. Moosoo XL-618A Battery Replacement, Battery: step 1, image 1 of 2 Moosoo XL-618A Battery Replacement, Battery: step 1, image 2 of 2
    • Press on the blue tab to release the battery pack, and pull.
  2. Moosoo XL-618A Battery Replacement: step 2, image 1 of 1
    • Remove each 15 mm screw from the four corners of the battery pack using a Phillips #1 screwdriver.
  3. Moosoo XL-618A Battery Replacement: step 3, image 1 of 2 Moosoo XL-618A Battery Replacement: step 3, image 2 of 2
    • Remove the back piece of the battery.
  4. Moosoo XL-618A Battery Replacement: step 4, image 1 of 2 Moosoo XL-618A Battery Replacement: step 4, image 2 of 2
    • Find the wire connecting the battery to the charging port, locate the black tab at the top of the pack and pull the tab out first then the battery.
    • Be careful not to pull the wire out of the battery itself as this will further damage the battery.
Kennedy E.
196 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 302
