Moosoo XL-618A Belt Replacement
  1. Moosoo XL-618A Belt Replacement, Motor: step 1, image 1 of 1
    • Remove the eight 11 mm screws on the bottom of the vacuum with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Belt Replacement: step 2, image 1 of 3 Moosoo XL-618A Belt Replacement: step 2, image 2 of 3 Moosoo XL-618A Belt Replacement: step 2, image 3 of 3
    • Pull the two hard plastic covers off of the floor brush piece.
  3. Moosoo XL-618A Belt Replacement: step 3, image 1 of 1
    • Remove the 9 mm screw to the motor with the Phillips #1 screwdriver.
  4. Moosoo XL-618A Belt Replacement: step 4, image 1 of 3 Moosoo XL-618A Belt Replacement: step 4, image 2 of 3 Moosoo XL-618A Belt Replacement: step 4, image 3 of 3
    • Take the motor and floor brush out of their slot and pull the floor brush off of the motor.
    • This is the perfect opportunity to clean the brush as well.
  5. Moosoo XL-618A Belt Replacement: step 5, image 1 of 3 Moosoo XL-618A Belt Replacement: step 5, image 2 of 3 Moosoo XL-618A Belt Replacement: step 5, image 3 of 3
    • Remove the two 9 mm screws with the Phillips #1 screwdriver and pull the plastic piece off of the motor.
  6. Moosoo XL-618A Belt Replacement, Belt: step 6, image 1 of 1
    • Take the plastic piece and pull the belt off of the wheel.
tommygourley
73 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 185
