Moosoo XL-618A Motherboard Replacement
  1. Moosoo XL-618A Motherboard Replacement, Motherboard: step 1, image 1 of 2 Moosoo XL-618A Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Motherboard Replacement: step 2, image 1 of 2 Moosoo XL-618A Motherboard Replacement: step 2, image 2 of 2
    • Using a spudger, open the device along the small lines that are visible to you. Go on to pry off all other detachable objects and set aside.
    • Make sure to not go too far as this could further damage the device.
  3. Moosoo XL-618A Motherboard Replacement: step 3, image 1 of 1
    • Pull the motherboard underneath the top handle of the top motor out and remove the connected wires. Then replace it with a new motherboard.
    • Be careful with the wires so that they don't get damaged in the process.
Ashtyn
489 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 81
All Time: 334
