Motherboard Cover Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Motherboard Cover Removal, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power off your phone.
  2. Motherboard Cover Removal, Separate the back cover: step 2, image 1 of 3 Motherboard Cover Removal, Separate the back cover: step 2, image 2 of 3 Motherboard Cover Removal, Separate the back cover: step 2, image 3 of 3
    • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
    • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
  3. Motherboard Cover Removal: step 3, image 1 of 3 Motherboard Cover Removal: step 3, image 2 of 3 Motherboard Cover Removal: step 3, image 3 of 3
    • Before separating the back cover, note the following:
    • There's a seam just under the back cover panel. Don't insert your tool here.
    • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
    • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
    • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
  4. Motherboard Cover Removal: step 4, image 1 of 3 Motherboard Cover Removal: step 4, image 2 of 3 Motherboard Cover Removal: step 4, image 3 of 3
    • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
  5. Motherboard Cover Removal, Remove the back cover: step 5, image 1 of 3 Motherboard Cover Removal, Remove the back cover: step 5, image 2 of 3 Motherboard Cover Removal, Remove the back cover: step 5, image 3 of 3
    • Lift and remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • If you're installing a new back cover:
    • Make sure you remove all liners from the underside.
    • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
    • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
  6. Motherboard Cover Removal, Remove the motherboard cover screws: step 6, image 1 of 2 Motherboard Cover Removal, Remove the motherboard cover screws: step 6, image 2 of 2
    • Use a T3 Torx screwdriver to remove the 11 screws securing the motherboard cover:
    • Five 4.9 mm‑long screws
    • Six 3.9 mm‑long screws
  7. Motherboard Cover Removal: step 7, image 1 of 1
    • Gently flip the graphite sheet on the battery over the top edge of your phone.
    • Be careful not to tear the sheet, as it's very delicate.
  8. Motherboard Cover Removal, Disconnect the battery: step 8, image 1 of 3 Motherboard Cover Removal, Disconnect the battery: step 8, image 2 of 3 Motherboard Cover Removal, Disconnect the battery: step 8, image 3 of 3
    • Insert the point of a spudger in the notch on the left edge of the battery connector cover and pry up to release its clips.
    • Only insert your tool enough to pry up the cover. Otherwise, you may accidentally disconnect the rear camera press connector.
    • Remove the cover.
    • During reassembly, firmly press the cover into place to engage the clips.
  9. Motherboard Cover Removal: step 9, image 1 of 3 Motherboard Cover Removal: step 9, image 2 of 3 Motherboard Cover Removal: step 9, image 3 of 3
    • Insert the tip of an opening pick under the top edge of the battery press connector and pry up to disconnect it.
    • Check if the rear camera press connector got disconnected during the previous step. If it did, reconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  10. Motherboard Cover Removal: step 10, image 1 of 3 Motherboard Cover Removal: step 10, image 2 of 3 Motherboard Cover Removal: step 10, image 3 of 3
    • Use your fingers to grip a bottom corner of the screen connector cover.
    • Lift the bottom edge of the cover and pull it towards the bottom of your phone to tear the "seal" sticker and remove the cover.
    • During reassembly, slide the tabs on the top edge of the cover under the motherboard cover and use the cutouts near the screw holes to align the cover.
  11. Motherboard Cover Removal, Remove the motherboard cover: step 11, image 1 of 3 Motherboard Cover Removal, Remove the motherboard cover: step 11, image 2 of 3 Motherboard Cover Removal, Remove the motherboard cover: step 11, image 3 of 3
    • Insert the point of a spudger in the notch near the center of the motherboard cover's left edge and pry up to release the clips.
    • Remove the motherboard cover.
    • During reassembly, put the cover onto the frame and press around the edges to engage the clips.
Finish Line
Spencer Day
158,120 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,887 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 68
