Motherboard Disconnection
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Motherboard Disconnection, Before you begin: step 1, image 1 of 3 Motherboard Disconnection, Before you begin: step 1, image 2 of 3 Motherboard Disconnection, Before you begin: step 1, image 3 of 3
    • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
    • Optionally, to drain the battery faster, navigate to More → Settings → Energy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
    • Unplug all cables and fully shut down your eReader.
    • Your screen should be black and say Powered off.
  2. Motherboard Disconnection, Insert an opening pick: step 2, image 1 of 3 Motherboard Disconnection, Insert an opening pick: step 2, image 2 of 3 Motherboard Disconnection, Insert an opening pick: step 2, image 3 of 3
    • Flip your eReader over so the screen is facing down.
    • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
    • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
    • You may have to test a few spots along the corner until the pick slides between one of the clips.
  3. Motherboard Disconnection, Release the right clips: step 3, image 1 of 3 Motherboard Disconnection, Release the right clips: step 3, image 2 of 3 Motherboard Disconnection, Release the right clips: step 3, image 3 of 3
    • Slide the pick toward the bottom right corner to release the clips along the right edge.
  4. Motherboard Disconnection: step 4, image 1 of 2 Motherboard Disconnection: step 4, image 2 of 2
    • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
  5. Motherboard Disconnection, Release the bottom clips: step 5, image 1 of 3 Motherboard Disconnection, Release the bottom clips: step 5, image 2 of 3 Motherboard Disconnection, Release the bottom clips: step 5, image 3 of 3
    • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
  6. Motherboard Disconnection, Remove the back cover: step 6, image 1 of 3 Motherboard Disconnection, Remove the back cover: step 6, image 2 of 3 Motherboard Disconnection, Remove the back cover: step 6, image 3 of 3
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
  7. Motherboard Disconnection, Coating information: step 7, image 1 of 3 Motherboard Disconnection, Coating information: step 7, image 2 of 3 Motherboard Disconnection, Coating information: step 7, image 3 of 3
    • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
  8. Motherboard Disconnection, Disconnect the battery: step 8, image 1 of 2 Motherboard Disconnection, Disconnect the battery: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
    • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
  9. Motherboard Disconnection, Soften the digitizer cables coating: step 9, image 1 of 2 Motherboard Disconnection, Soften the digitizer cables coating: step 9, image 2 of 2
    • Heat an iOpener and lay it on the digitizer cable ZIF connectors for 90 seconds to soften the coating.
    • Alternatively, you can use a hair dryer or a heat gun for 30 seconds.
  10. Motherboard Disconnection, Remove the coating: step 10, image 1 of 3 Motherboard Disconnection, Remove the coating: step 10, image 2 of 3 Motherboard Disconnection, Remove the coating: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tip of a spudger to scrape the coating along the ZIF connectors' black locking tabs—enough so you can grab clumps of it with pointed tweezers.
    • Use pointed tweezers to peel off the coating around the black locking tabs and their hinges on the ZIF connector.
    • If the coating becomes too brittle and hard to peel off, reheat the connectors and try again.
    • This is a meticulous process! Failure to remove enough of the coating could damage the locking tab during disconnection, so take your time!
  11. Motherboard Disconnection, Disconnect the digitizer cables: step 11, image 1 of 3 Motherboard Disconnection, Disconnect the digitizer cables: step 11, image 2 of 3 Motherboard Disconnection, Disconnect the digitizer cables: step 11, image 3 of 3
    • Use the point of a spudger to lift up the locking tabs on the ZIF connectors.
    • The locking tabs should be nearly vertical when unlocked. If not, remove more coating until the tabs can move freely.
  12. Motherboard Disconnection, Reheat the digitizer cables: step 12, image 1 of 1
    • Apply a heated iOpener to the digitizer cable ZIF connectors for 90 seconds to soften the coating.
  13. Motherboard Disconnection: step 13, image 1 of 3 Motherboard Disconnection: step 13, image 2 of 3 Motherboard Disconnection: step 13, image 3 of 3
    • Slide one arm of a pair of pointed tweezers underneath the cables to separate the coating securing them to the motherboard.
    • You only need to separate enough coating so you can grip the cables with blunt nose tweezers.
  14. Motherboard Disconnection: step 14, image 1 of 3 Motherboard Disconnection: step 14, image 2 of 3 Motherboard Disconnection: step 14, image 3 of 3
    • Because of the awkward angle, this step requires some patience to avoid tearing the cables. Work slowly and apply heat regularly.
    • Use blunt nose tweezers to pull the cables away from their ZIF connectors slowly and steadily at a level angle to separate the coating.
    • Gripping the tweezers closer to the tip can help get a tighter hold on the cables.
    • Keep pulling on the cables until they're completely disconnected.
    • During reassembly:
    • Inspect the ends of the cables and the ZIF connectors for any remaining coating that could prevent a good connection.
    • Peel off the coating, heating the cable and the ZIF connectors when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cables sit properly in their connectors.
  15. Motherboard Disconnection, Soften the display cable coating: step 15, image 1 of 2 Motherboard Disconnection, Soften the display cable coating: step 15, image 2 of 2
    • Apply a heated iOpener to the display cable ZIF connector for 90 seconds to soften the coating.
  16. Motherboard Disconnection, Remove the coating: step 16, image 1 of 3 Motherboard Disconnection, Remove the coating: step 16, image 2 of 3 Motherboard Disconnection, Remove the coating: step 16, image 3 of 3
    • The display cable ZIF connector is larger and requires a different procedure to disconnect properly.
    • Use the tip of a spudger to scrape the coating along the ZIF connector's black locking tab—enough so you can grab clumps of it with pointed tweezers.
  17. Motherboard Disconnection: step 17, image 1 of 3 Motherboard Disconnection: step 17, image 2 of 3 Motherboard Disconnection: step 17, image 3 of 3
    • Use pointed tweezers to peel off the coating around the locking tab and its hinge on the ZIF connector.
    • If the coating becomes too brittle and hard to peel off, reheat the connector and try again.
  18. Motherboard Disconnection: step 18, image 1 of 2 Motherboard Disconnection: step 18, image 2 of 2
    • Use the flat end of a spudger to gently pry along the length of the locking tab to separate any remaining coating.
    • Don't pry hard at the corners of the locking tab to avoid snapping it.
  19. Motherboard Disconnection, Disconnect the display cable: step 19, image 1 of 2 Motherboard Disconnection, Disconnect the display cable: step 19, image 2 of 2
    • Insert the flat end of a spudger under the middle of the locking tab and lift to unlock it.
    • The locking tab should be nearly vertical when unlocked. If not, remove more coating until the tab can move freely.
  20. Motherboard Disconnection: step 20, image 1 of 2 Motherboard Disconnection: step 20, image 2 of 2
    • Use blunt nose tweezers to grip the corner of the display cable closest to the charging port.
    • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating at the corner.
    • If you're having trouble, try rocking the cable side-to-side while pulling.
    • Gripping the tweezers closer to the tip can help with getting a tighter hold on the cable.
  21. Motherboard Disconnection: step 21, image 1 of 3 Motherboard Disconnection: step 21, image 2 of 3 Motherboard Disconnection: step 21, image 3 of 3
    • Repeat the previous step for the other corner until the entire cable is disconnected.
    • Lift up the cable and peel off any remaining coating holding it to the motherboard.
    • Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
    • Peel off the coating, heating the cable and the ZIF connector when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
Alex Diaz-Kokaisl
129,330 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 91
