Moto C Plus Earpiece Speaker Replacement
  1. Moto C Plus Earpiece Speaker Replacement, Back Cover: step 1, image 1 of 3 Moto C Plus Earpiece Speaker Replacement, Back Cover: step 1, image 2 of 3 Moto C Plus Earpiece Speaker Replacement, Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Earpiece Speaker Replacement: step 2, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 2, image 2 of 2
    • Lift the phone out of the back cover.
  3. Moto C Plus Earpiece Speaker Replacement, Battery: step 3, image 1 of 3 Moto C Plus Earpiece Speaker Replacement, Battery: step 3, image 2 of 3 Moto C Plus Earpiece Speaker Replacement, Battery: step 3, image 3 of 3
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Moto C Plus Earpiece Speaker Replacement, Daughterboard Cover: step 4, image 1 of 1
    • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
  5. Moto C Plus Earpiece Speaker Replacement: step 5, image 1 of 3 Moto C Plus Earpiece Speaker Replacement: step 5, image 2 of 3 Moto C Plus Earpiece Speaker Replacement: step 5, image 3 of 3
    • Apply a spudger to the right side of the daughterboard cover.
    • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
    • Remove the daughterboard cover.
  6. Moto C Plus Earpiece Speaker Replacement, Motherboard Cover: step 6, image 1 of 1
    • Remove the five 3.1 mm long Phillips #00 screws.
  7. Moto C Plus Earpiece Speaker Replacement: step 7, image 1 of 3 Moto C Plus Earpiece Speaker Replacement: step 7, image 2 of 3 Moto C Plus Earpiece Speaker Replacement: step 7, image 3 of 3
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  8. Moto C Plus Earpiece Speaker Replacement: step 8, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 8, image 2 of 2
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  9. Moto C Plus Earpiece Speaker Replacement, Motherboard Assembly: step 9, image 1 of 1
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
  10. Moto C Plus Earpiece Speaker Replacement: step 10, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 10, image 2 of 2
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
  11. Moto C Plus Earpiece Speaker Replacement: step 11, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  12. Moto C Plus Earpiece Speaker Replacement: step 12, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 12, image 2 of 2
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  13. Moto C Plus Earpiece Speaker Replacement: step 13, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 13, image 2 of 2
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  14. Moto C Plus Earpiece Speaker Replacement: step 14, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 14, image 2 of 2
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  15. Moto C Plus Earpiece Speaker Replacement: step 15, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 15, image 2 of 2
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  16. Moto C Plus Earpiece Speaker Replacement: step 16, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 16, image 2 of 2
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  17. Moto C Plus Earpiece Speaker Replacement: step 17, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 17, image 2 of 2
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  18. Moto C Plus Earpiece Speaker Replacement: step 18, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 18, image 2 of 2
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  19. Moto C Plus Earpiece Speaker Replacement: step 19, image 1 of 1
    • Remove the motherboard.
  20. Moto C Plus Earpiece Speaker Replacement, Earpiece Speaker: step 20, image 1 of 1
    • Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
  21. Moto C Plus Earpiece Speaker Replacement: step 21, image 1 of 2 Moto C Plus Earpiece Speaker Replacement: step 21, image 2 of 2
    Buy
    • Use a pair of tweezers to carefully grab and remove the earpiece speaker.
2 other people completed this guide.
Dominik Schnabelrauch
209,996 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,893 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,131
