Moto G6 Plus Rear Glass Replacement
  1. Moto G6 Plus Rear Glass Replacement, Remove the rear glass: step 1, image 1 of 1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
    • Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Moto G6 Plus Rear Glass Replacement: step 2, image 1 of 3 Moto G6 Plus Rear Glass Replacement: step 2, image 2 of 3 Moto G6 Plus Rear Glass Replacement: step 2, image 3 of 3
    • Apply a suction cup to the bottom edge of the rear glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • If the glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
    • Insert an opening pick into the gap you created under the rear glass.
  3. Moto G6 Plus Rear Glass Replacement: step 3, image 1 of 3 Moto G6 Plus Rear Glass Replacement: step 3, image 2 of 3 Moto G6 Plus Rear Glass Replacement: step 3, image 3 of 3
    • Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Slow down and slice very gently as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. You can repeat this with each edge, leaving a pick and continuing with a new one.
  4. Moto G6 Plus Rear Glass Replacement: step 4, image 1 of 1
    • Heat the right edge of the back of the phone to soften the adhesive underneath.
  5. Moto G6 Plus Rear Glass Replacement: step 5, image 1 of 3 Moto G6 Plus Rear Glass Replacement: step 5, image 2 of 3 Moto G6 Plus Rear Glass Replacement: step 5, image 3 of 3
    • Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
  6. Moto G6 Plus Rear Glass Replacement: step 6, image 1 of 1
    • Heat the top edge of the back of the phone to soften the rear glass adhesive.
  7. Moto G6 Plus Rear Glass Replacement: step 7, image 1 of 3 Moto G6 Plus Rear Glass Replacement: step 7, image 2 of 3 Moto G6 Plus Rear Glass Replacement: step 7, image 3 of 3
    • Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
  8. Moto G6 Plus Rear Glass Replacement: step 8, image 1 of 1
    • Heat the left edge of the back of the phone to soften the adhesive underneath.
  9. Moto G6 Plus Rear Glass Replacement: step 9, image 1 of 3 Moto G6 Plus Rear Glass Replacement: step 9, image 2 of 3 Moto G6 Plus Rear Glass Replacement: step 9, image 3 of 3
    • Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
  10. Moto G6 Plus Rear Glass Replacement: step 10, image 1 of 2 Moto G6 Plus Rear Glass Replacement: step 10, image 2 of 2
    Tool used on this step:
    Tesa 61395 Tape
    $5.99
    Buy
    • If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the rear glass carefully, making sure it's fully separated from any adhesive.
    • Remove the rear glass.
    • During reassembly, pause here to replace the adhesive on the rear glass using a precut adhesive card or high-strength double-sided adhesive tape, such as Tesa 61395.
2 other people completed this guide.
Adam O'Camb
198,533 Reputation
416 Guides authored
2 Comments
Agradecer a todos que fazem o ifixit de grande ajuda para técnicos e principalmente para aqueles iniciantes
antonio noberto - Reply
Agradecer a todos que fazem o ifixit de grande ajuda para o técnico principalmente para a queles iniciantes
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 2,748
