Moto Z Fingerprint Sensor Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Moto Z Fingerprint Sensor Replacement, Display: step 1, image 1 of 2 Moto Z Fingerprint Sensor Replacement, Display: step 1, image 2 of 2
    • Position the opening tool under the lid of the screen.
    • Slide the opening tool around the edge of the screen to loosen the adhesive.
  2. Moto Z Fingerprint Sensor Replacement: step 2, image 1 of 1
    • Lift the screen off the body from the top.
  3. Moto Z Fingerprint Sensor Replacement: step 3, image 1 of 2 Moto Z Fingerprint Sensor Replacement: step 3, image 2 of 2
    • To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab.
    • Lift up, removing the tab from the device.
  4. Moto Z Fingerprint Sensor Replacement: step 4, image 1 of 1
    • Pull the screen up to fully remove it.
  5. Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 1 of 2 Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Insert the tweezers under the metal backing of the sensor.
    • Lift up the backing until it is detached from the phone.
  6. Moto Z Fingerprint Sensor Replacement: step 6, image 1 of 2 Moto Z Fingerprint Sensor Replacement: step 6, image 2 of 2
    • With the tweezers, grab the black connector located just above the fingerprint scanner.
    • Pull the connector to the right until it is detached from the phone.
Miriam Lam
1,188 Reputation
5 Guides authored
Cal Poly, Team S2-G2, Livingston Winter 2018 Member of Cal Poly, Team S2-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 328
