Motorola C168 Front Panel Replacement
  1. Motorola C168 Front Panel Replacement, Battery: step 1, image 1 of 2 Motorola C168 Front Panel Replacement, Battery: step 1, image 2 of 2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: step 2, image 1 of 2 Motorola C168 Front Panel Replacement: step 2, image 2 of 2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: step 3, image 1 of 2 Motorola C168 Front Panel Replacement, SIM Card: step 3, image 2 of 2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: step 4, image 1 of 2 Motorola C168 Front Panel Replacement, Front Panel: step 4, image 2 of 2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: step 5, image 1 of 2 Motorola C168 Front Panel Replacement: step 5, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
Christopher Wu
37 Reputation
3 Guides authored
Cal Poly, Team 12-40, Regan Spring 2012 Member of Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,134
