Motorola C290 Antenna Replacement
  1. Motorola C290 Antenna Replacement, Battery: step 1, image 1 of 2 Motorola C290 Antenna Replacement, Battery: step 1, image 2 of 2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Antenna Replacement: step 2, image 1 of 2 Motorola C290 Antenna Replacement: step 2, image 2 of 2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Antenna Replacement, Antenna: step 3, image 1 of 3 Motorola C290 Antenna Replacement, Antenna: step 3, image 2 of 3 Motorola C290 Antenna Replacement, Antenna: step 3, image 3 of 3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Antenna Replacement: step 4, image 1 of 2 Motorola C290 Antenna Replacement: step 4, image 2 of 2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Angelo Ballungay
79 Reputation
4 Guides authored
Cal Poly, Team 24-28, Regan Spring 2010 Member of Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,999
