Motorola C290 Screen Replacement
  1. Motorola C290 Screen Replacement, Outside Case removal: step 1, image 1 of 3 Motorola C290 Screen Replacement, Outside Case removal: step 1, image 2 of 3 Motorola C290 Screen Replacement, Outside Case removal: step 1, image 3 of 3
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Screen Replacement, Removing the front casing: step 2, image 1 of 2 Motorola C290 Screen Replacement, Removing the front casing: step 2, image 2 of 2
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Screen Replacement, Disconnect the motherboard: step 3, image 1 of 2 Motorola C290 Screen Replacement, Disconnect the motherboard: step 3, image 2 of 2
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Screen Replacement, Removing the motherboard/screen: step 4, image 1 of 3 Motorola C290 Screen Replacement, Removing the motherboard/screen: step 4, image 2 of 3 Motorola C290 Screen Replacement, Removing the motherboard/screen: step 4, image 3 of 3
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
Angelo Ballungay
79 Reputation
4 Guides authored
Cal Poly, Team 24-28, Regan Spring 2010 Member of Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,771
