Motorola Defy Antenna Replacement
  1. Motorola Defy Antenna Replacement, Rear Case: step 1, image 1 of 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Antenna Replacement: step 2, image 1 of 2 Motorola Defy Antenna Replacement: step 2, image 2 of 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Antenna Replacement, Battery: step 3, image 1 of 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Antenna Replacement, Antenna: step 4, image 1 of 2 Motorola Defy Antenna Replacement, Antenna: step 4, image 2 of 2
    • Take the metal spudger and pry the black piece, where the sim card goes, off to get to the entire antenna.
  5. Motorola Defy Antenna Replacement: step 5, image 1 of 3 Motorola Defy Antenna Replacement: step 5, image 2 of 3 Motorola Defy Antenna Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Pry the antenna off using the metal spudger and tweezers and replace with the new one.
Morgan Roark
325 Reputation
3 Guides authored
USF Tampa, Team 14-2, Leahy Fall 2014 Member of USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 886
