Motorola Defy LCD Replacement
  1. Motorola Defy LCD Replacement, Rear Case: step 1, image 1 of 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy LCD Replacement: step 2, image 1 of 2 Motorola Defy LCD Replacement: step 2, image 2 of 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy LCD Replacement, Battery: step 3, image 1 of 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy LCD Replacement, Midframe: step 4, image 1 of 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy LCD Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy LCD Replacement, Motherboard: step 6, image 1 of 2 Motorola Defy LCD Replacement, Motherboard: step 6, image 2 of 2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy LCD Replacement: step 7, image 1 of 3 Motorola Defy LCD Replacement: step 7, image 2 of 3 Motorola Defy LCD Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy LCD Replacement: step 8, image 1 of 1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy LCD Replacement, Removing the LCD: step 9, image 1 of 2 Motorola Defy LCD Replacement, Removing the LCD: step 9, image 2 of 2
    • Stick the metal spudger in between the LCD screen and the case of the phone.
    • Remove the LCD screen and replace with a new one.
2 other people completed this guide.
Ebrahem AlRayes
183 Reputation
1 Guide authored
USF Tampa, Team 14-2, Leahy Fall 2014 Member of USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,254
